ESBE Thermostatic Mixing Valve replacement
initram
Member Posts: 15
Hello,
Does anyone know where I can get a replacement ESBE thermostatic mixing valve for domestic hot water? (I'm in Sudbury, Ontario) I've called all local suppliers and they all carry Watts or Honeywell. I'd rather stick with the ESBE as it has an asymmetrical design and the other brands don't and would require some unnecessary plumbing. I need to replace it because it is no longer working properly. When I set it to min. or max. the water temperature remains the same. It also allows the hot water to back-flow into the cold water source resulting in warm water coming out of my taps. So I would need one that has an integrated check valve. According to ESBE I think I would need model VTA322 3110 06 00.
http://www.esbe.eu/global/en/~/media/ESBE PIM_ESBE sync BR/Documents/Data sheets/GB/VTA320_520_GB_D_LR.ashx
The one I currently have is model T30 2583 (That's what is listed on the body of the valve under the plastic casing you see in the picture). I tried searching for online for any info I could find with the numbers on the valve but it seems like it's a discontinued/undocumented model.
So if anyone can help me locate one of these mixing valves it would be greatly appreciated. Other brand recommendations are welcome as well... as long as they have integrated check valves. I will consider them if I really can't find a ESBE replacement.
Thank you.
Thank you.
Try googling it. Danfos makes or owns it, I believe.Bob Boan
Danfoss is the Canadian distributor for ESBE... but they do not seem to sell directly to the public. I emailed them but never got an answer.0
Try here:
http://www.supplyhouse.com/Danfoss-082F8994-Rebuild-Kit-for-ESBE-Series-20-Thermostatic-Mixing-ValveBob Boan
- 116 Geothermal
- 169 Indoor-Air Quality
