New Rads...or old
vaporvac
Member Posts: 1,520
I need a new (or old) single rad for my kitchen. It can be Cast iron or steel, although I feel the CI is probably better. Thoughts? Does anyone still manufacture these? It's a tight space behind a door, but it's all that's available near the old piping. Then I'll need help figuring out how to pipe it in, but I want to find a rad first. Thanks in advance. Colleen
Craigslist is your friend. THere are always cast iron rads listed (at least in my area)0
And new ones can also be had. They aren't cheap.Br. Jamie, osb
Thank you. I've been looking on craigslist for a LONG while, but the singles are apparently hard to come by. I'll keep looking, but am about to put in my new to me chambers stove which will require taking out the cabinetry temporarily, so I thought I'd try and do something about the heating at the same time.
Anyone know who still makes rads, bot CI and steel? Are there any problems mixing the two types?Two-pipe Trane vaporvacuum system; 1466 edr
Burnham for one -- they make a "slenderized" radiator which looks a lot like the older ones, only not ornate.
I'd stick with cast iron.Br. Jamie, osb
Here is the link https://file.ac/-TAxJ9ayqks/classic-product-literature.pdf0
delete0
Another vote for Cast Iron. Craigslist or even eBay (local pickup) is probably your best bet. I would also check local salvage places... call around, if they don't have them ask them if they know anyone who might.
BTW... I have a couple of the (6-tube) slenderized Burnham radiators in my steam setup. I didn't buy them new... so I can't speak to cost factor, but they do work extremely well.
They seem to be far more efficient than my old Aeros and the 25" tall form factor can be handy in places where you don't want to go tall.
S.P.Burnham IN6 |one-pipe steam
Boiling water for heat since 2006.0 -
Hello all! I have located a possible contender thanks to this thread: http://forum.heatinghelp.com/discussion/151649/cast-iron-rads-for-sale-near-pottstown-pa#latest
It's the wall-hung unit with brackets. I don't know if this is a good $$$, but it will fit the space. I havent yet figured the edr, although I'm sure it's less than the original window seat model.
My questions are thus: What should be included with this to ensure I can use it. I recall something about having both ends of the connections the same? Does this rad look complete? where can I look to calculate its EDR?
What do I need to keep in mind as this rad will use the same inlet/outlet, but will be moved about 3-4ft left of the original position? I guess what I really want to know are what pitfalls to avoid when moving a rad. I know steam can go anywhere, but condensate is a different story.
This rad is about 500miles from me, so I don't even know how I'll get it, but no sense even thinking about it if it won't work. Thank you, everyone.
It will be nice not to really on the baseboard heater in the kitchen anymore.Two-pipe Trane vaporvacuum system; 1466 edr
Did you ever figure how to pipe your future radiator in your kitchen? Surely someone on this forum knows how to pipe that radiator.0
Don't know where you live but we also were looking for a used radiator, not much out there as I would assume that they have been traded in for scrap.
I will be taking a ride into Brooklyn in the next couple of weeks.
OCS Industries
They have most everything in stock.
Gene in Northern NJ
NJ HVACR License 19HC005376000
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
