Well the new boiler is finished and running!
KC_Jones
Member Posts: 5,885
Wanted to thank everyone on this site for all the input and advice either directly or indirectly (I read a lot of old posts). I finished the install today and fired the boiler off. Everything is running smoothly and I couldn't be happier with the final results. Here are a few pics of the completed install. I installed a lo/hi fire system (Maxitrol) and tried to incorporate as many suggested "extras" I read about on this site. I hope I did justice to the "Dead Men".
1
i'm quite impressed! very nice indeed.gwgillplumbingandheating.com
That should serve you well for a long time, well done.
The only quibble I have is the use of an auto water feeder. I would valve it off unless I was going to be away from the house on vacation. My complaint with them is they lead to complacency, a boiler needs to be looked at a few times a week to feel the love. I also detest them because the wrong kind can surreptitiously feed water and mask system problems but the meter on that one negates that fear.
I would be happy to have a boiler that well done in my own house.
3PSI gauge0 -
Very nice piping there, looks good.
What model boiler is it, looks like EG40??
One question, why did you reduce the risers instead of running them full up to the header?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Well done- and that VXT is the only water feeder to use, with its digital counter that tracks water usage.All Steamed Up, Inc.
Consulting0 -
I had posted a picture of my proposed piping design a while ago and it was suggested that doing it this way versus bushing it down right at the outlet would help reduce the initial steam velocity. The cost wasn't that much more so I did it. I didn't see the point on this size boiler in doing full 3" risers since I was only doing a 3" header the 2-2" risers match the volume of a 3" header pretty well so I went that route. Weil McLain says 1 2 1/2" riser at a minimum so I am easily exceeding that. Oh and yes it's an EG-40. Had a 45 before which was oversized and honestly the 40 is oversized, but I plan on some small additions to the house and I have a couple rooms that don't have rads now and will need something added at some point. This boiler leaves me about 60 sq. ft. to play with and honestly the 35 would have been a hair to small for the current set up. The low fire should help as well. The last thing I need to do is get my uncle to bring his equipment up and tune the gas valve for me....low is a bit too low right now. Thank you all for the compliments I am pretty proud of the results.Dave0176 said:Very nice piping there, looks good.
One question, why did you reduce the risers instead of running them full up to the header?0 -
Wow KC! It looks like a GREAT Install. It should give you years of comfort.0
Little bit of artistry and magic there. Well done...0
nice job!0
lol it's just shoved in there to keep it off the floor. I have since added a copper "holster" for the hose on the side of the jacket.0
Looks awesome! Congratulations!0
Looks like a great job. I'm sure you will enjoy the quiet of the heat this winter.Gene in Northern NJ
NJ HVACR License 19HC005376000 -
Wow KC, looks neat, professional and clean. Congrats! You should be proud0
I just noticed your skim port does not have a plug on it. If someone were to open that valve while the boiler was making steam the results could be tragic. I put a threaded plug on mine just for peace of mind, you can see the threaded plug sitting on top of the boiler.
3PSI gauge0 -
It's plugged. I was still doing skimming when those pics were taken. After the last skim I installed the plug. Oh and in my house nobody, but me wants to go into that "dirty basement". lol Also if you look closely you can actually see the plug sitting on top of the boiler in the one picture.0
Very impressive!Steve Minnich0
Excellent!! When craftsmanship rises to this level of perfection it become a piece of art. Well Done!
However, there appears to be something seriously wrong with your boiler. I see flames rising up on the front panel. Doesn't this thing have a rollout switch? If so, it must be damaged. You need to get this fixed before you burn your house down.
Dave in Quad Cities, America
http://grandviewdavenport.com0 -
I did that on purpose to stop from wasting all the heat up the chimney. Bypass the rollout switch and close off the flue, instant workshop heat! lol1
I didn't know heat pumps had sight glases on them. Lol I'm kidding.
Looks great nice job!0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
