New replacement with lots of pics
Dave0176
Dave0176 Member Posts: 1,178
edited October 2014 in Strictly Steam
The old boiler was an 11 year old 150,000 btu Utica with single 2" copper riser and header that he fed into a 2-1/2x2x3" bushed down to 2" on the bull, bullhead tee. Owner told told me the heat never worked well, the third floor radiator didn't get hot unless he turned the tstat waaay up, then they roasted in the first floor. The porch was enclosed and the old plumber talked him into a hot water loop off the boiler, which he ran wrong, no bypass loop, only one flo control.
I did the best I could, was inspired by jstar with the header build. The boiler is a Williamson GSA 125,000 BTU (Weil McLain EG40) I ran a 3" header with two 2-1/2" risers, a 2" equilizer, one 2-1/2" main and one 2" main, used two No. 2 and one No. 1 Gortons on the main return.
Here it is on the first fire up almost done, just have finish
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
