New replacement with lots of pics
Dave0176
Member Posts: 1,177
The old boiler was an 11 year old 150,000 btu Utica with single 2" copper riser and header that he fed into a 2-1/2x2x3" bushed down to 2" on the bull, bullhead tee. Owner told told me the heat never worked well, the third floor radiator didn't get hot unless he turned the tstat waaay up, then they roasted in the first floor. The porch was enclosed and the old plumber talked him into a hot water loop off the boiler, which he ran wrong, no bypass loop, only one flo control.
I did the best I could, was inspired by jstar with the header build. The boiler is a Williamson GSA 125,000 BTU (Weil McLain EG40) I ran a 3" header with two 2-1/2" risers, a 2" equilizer, one 2-1/2" main and one 2" main, used two No. 2 and one No. 1 Gortons on the main return.
Here it is on the first fire up almost done, just have finish
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Well those pic didn't work lolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
This one sideways I give upDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
MoreDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Did you bush the supply tappings down to 2"?
I thought that boiler came with 2- 3" connections on top.0 -
Bushed supply tappings down to 2-1/2"Robert O'Connor said:Did you bush the supply tappings down to 2"?
I thought that boiler came with 2- 3" connections on top.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
i like it..thats a first rate install.gwgillplumbingandheating.com
Two 2-1/2" supply tappings on that boiler give 13.08 FPS steam exit velocity.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Nice work.
I'm sure it will produce dry steam.
my velocity chart shows that You could have done the piping with two 2" risers (14.88fps) in each and one 2.5 " header with 20.92fps
I also install a 10" or 12" nipple after the second riser ties in before I install a takeoff. I think it allows the steam to settle down a little bit after the two risers come together.
This would also let you install a full size 90 degree elbow aiming straight down to the equalizer before you reduce to 2"
I also install the vertical pile to the take off ones size bigger that the overheadSince 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
From Gerry Gill, now that's a compliment, I've seen your site and work. Thank yougerry gill said:i like it..thats a first rate install.
That's as good a drop header as I've seen. Does the aquastat on the HW loop work well in that location?All Steamed Up, Inc.
Consulting0 -
Well I'm soon to find out, it's right after the pump and flo control on the supply side.Steamhead said:That's as good a drop header as I've seen. Does the aquastat on the HW loop work well in that location?
I have to admit my 6 yo son did help me build the header. He had to at least try to tighten a fitting all while I supported the 36" pipe wrench, since it probably weighs more then him lol. He'll be there with me in the future.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
BTW monster tape is awesome, I will use it on everything in the future. I used that combined with Mega Lock.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
FinishedDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Its as good as it gets! just an outstanding job. I don't see anything to improve upon. Well Done!gwgillplumbingandheating.com
As you can see that horizontal pipe running under that window is well below the "A" Dimention, so I ask the owner does he get water hammer there, he says yes, so I explain that horizontal run should've just dripped straight down and made a wet return as the old dry return was replaced because it ran down the middle of the basement and was very low. They had good intentions but failed to understand the A Dimention.
He doesn't want to replace it anyway, so I said call me when you get tired of the banging, I'll fix it.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
