COPPER FIN RADIATION
bob young
Member Posts: 2,177
any comments on using pex tubing for a simple baseboard radiation job , one family ,single zone as oppossed to conventional 3/4 " m copper tube w/ soldered joints. cost efficient is a given but i am concerned with system temperatures in piping & radiation. modern builders want to cut cost of contracts to the bone. bob young nyc lic. plbr
thanx, hot rod. how goes it ,brother. been a while. i just dislike the plastic tubing & especially the unprofessional installation as compared to copper. plumbers die hard !!! bob nyc0
copper with press fittings is another option. Takes some of the labor and torch issues away.
Years ago we jumped on the rubber tube for BB systems. A breeze to install, quiet, semi insulated, great for retro-fits.
An expensive lesson learned with that early Entran rubber hydronic tube, however, as you know.
Some will tell you the current version of the "uber" engineered Watts Onix rubber is suitable for high temperature hydronics, if you like to gamble
More heat delivered where it matters with the PAP or Pex Bob . Been around a long time too , took awhile to get used to the idea . We gotta evolve or go the way of the dinosaur , don't see many of them anymore do you ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
We've had a kickspace heater in our kitchen for 20 years. It runs off of Entran 3 and at temps up to 180. So far, so good.hot rod said:copper with press fittings is another option. Takes some of the labor and torch issues away.
Retired and loving it.0 -
i get the message ,rich. loud & clear. guess i am not THAT opposed , just hate the look. too much like linguine gone wild !!!! lol bob nyc0
It can be made to look good Bob . It does take some practice thoughYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
PAP has about the same rigidity as soft copper and can be neatly bent with a ratchet bender in the 1/2 to 3/4 sizes. You can also stub down with copper and adapt to PAP under the floor. They also have 90* Ells that transition so you can do it right at the element if you choose.bob young said:i get the message ,rich. loud & clear. guess i am not THAT opposed , just hate the look. too much like linguine gone wild !!!! lol bob nyc
Bob Boan
LOOKIN, GOOD ,RICH. HOT ROD PROBABLY DOES IT SIMILAR. AFTER SEEING A JOB LOOKING THAT GOOD I WOULD CONSIDER GIVING IT A SHOT. I THANK YOU KINDLY. ALWAYS PAYS TO TAKE A SECOND LOOK !! BOB NYC0
- 62 Biomass
