two remote radiators not working
RLS
RLS Member Posts: 4
Two of the more radiators in one pipe steam system either underperforming or not performing at all when all the others on all floors and sides of the building work fine. Three story 1915 Victorian with five year old steam boiler. See attached schematic
  • End of the line rads cold
    Is this a parallel flow or counter flow system?
    What sort of main vents are on the dry returns if parallel?
    Can you try the open vent test? You need a helper to switch off the boiler when steam arrives.
    If your pressure is above 1.5 psi, some radiator vents will not work.--NBC
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    the old rule is...
    Vent your mains fast and vent your radiators slow, but completely.
    Any combination of slow main vents and fast radiator vents will play heck with even steam distribution, causing the last radiators, to not get steam.
    Since you have a new boiler, pictures of the piping connecting to the boiler as well as your radiators and vents would be a great help to those of us who are trying to get a handle on your system and offer sound advice.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Jamie Hall Member Posts: 26,757
    Does sound
    like a venting problem.  If the air can't get out, the steam can't get in.  Check those vents.
