Long Island - code question
JohnNY
JohnNY Member Posts: 3,341
Is there any reason to believe that backflow preventers on boilers and mixing valves on indirect water heaters are not both code requirements? Am I at least half right to think thy are?
Thanks in advance. I'm only licensed in the City of New York.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
  • Rich_49
    Rich_49 Member Posts: 2,785
    edited September 2014
    In Lawn Guyland , NYC and everywhere
    Boilers should definitely all require BFP and all water heaters should require a TAMV .  Water heaters as you are all aware have much hotter water at top where delivered water is first drawn from . We should eliminate that risk .  We could probably do away with a lot of redundancy using different valves at different locations . Maybe all the valves for all the different ASSE requirements should go right at the unit as opposed to all over the damn place .  On the fixture side of any of these a sensor could be placed and upon too high temp a valve could be closed .  Seen too many valves at fixtures fail and people getting scolded . Except the 1016 ASSE valves that are right where they should be .
    732-751-1560
    Rich McGrath 732-581-3833
  • JohnNY
    Yeah, but
    I'm asking a Code question.
    Is it Code or not to have a BFP, and separately, a mixing valve?
    Classes
  • Rich_49
    You
    obviously know the answer so why are you inquiring ? Did an inspector tell you that you could not install one or the other ?  I don't understand the question , you know they are needed , INSTALL them .  What are the model codes adopted there ?
    732-751-1560
  • JohnNY
    I don't know the answer for sure.
    That's why I'm asking. I know the codes in NYC and a friend of mine in Amagansett just had this work done and asked me to take a look at it.
    It's a decent installation but it's missing backflow protection and a mixing device.
    Classes
  • JohnNY
    That's why I'm asking. I'm not one of these people that likes to shout out his opinion on the internet. I'd like to know the facts before I make a comment to the concerned parties.
    I did. It's a decent-looking installation but it's missing backflow protection and a mixing device.
    If it's code, I have to call the installing plumber and tell him he's got to go back.
    Classes
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    It's Town by Town on LI
    And they are not on the same page all the time. Amagansett is in Town of East Hampton, I can't say for certain what they require but it is code in all the towns I am familiar with.
  • Danny Scully
    Danny Scully Member Posts: 1,465
    There is no "Long Island" code.
    As Robert suggested, it's town by town. You'll need to contact the inspector. Speaking of which, was the work inspected?
  • jonny88
    jonny88 Member Posts: 1,139
    Not that easy out here
    John,I worked in the city for 15yrs.The one thing I never understood when I moved out to Long Island was the B/S you have to go through.The amount of areas that require different licenses and how the codes are different in many towns.Whenever I am unsure I always call plumbing dept and you will get an answer from a inspector.Call the town at 7.30 am that is usually when you can get them.It amazes me why there cant be either a county license or Ny license excluding the five boroughs as we all know the real challenging plumbing is done in the city.I understand your frustrations but I think the only way you will know is to call inspector.(even though you know the answer).But again if it is code the plumber has to go back and do right.
  • icesailor
    icesailor Member Posts: 7,260
    Amagansett:
    I have a daughter that lives in Amagansett. She built a new house a few years ago. It was the first place I ever saw an oil tank vent and fill piped with copper tube. DWV copper tube. It seemed to be sort of wild west territory way out there.
    There was a BFD on the boiler. The house is on a well.
  • JohnNY
    Thank you for your replies.
    I'm going to give the Town a call.
    Best to all,
    John
    Classes
