Long Island - code question
JohnNY
Member Posts: 3,231
Is there any reason to believe that backflow preventers on boilers and mixing valves on indirect water heaters are not both code requirements? Am I at least half right to think thy are?
Thanks in advance. I'm only licensed in the City of New York.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
In Lawn Guyland , NYC and everywhere
Boilers should definitely all require BFP and all water heaters should require a TAMV . Water heaters as you are all aware have much hotter water at top where delivered water is first drawn from . We should eliminate that risk . We could probably do away with a lot of redundancy using different valves at different locations . Maybe all the valves for all the different ASSE requirements should go right at the unit as opposed to all over the damn place . On the fixture side of any of these a sensor could be placed and upon too high temp a valve could be closed . Seen too many valves at fixtures fail and people getting scolded . Except the 1016 ASSE valves that are right where they should be .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Yeah, but
I'm asking a Code question.
Is it Code or not to have a BFP, and separately, a mixing valve?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
You
obviously know the answer so why are you inquiring ? Did an inspector tell you that you could not install one or the other ? I don't understand the question , you know they are needed , INSTALL them . What are the model codes adopted there ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
I don't know the answer for sure.
That's why I'm asking. I know the codes in NYC and a friend of mine in Amagansett just had this work done and asked me to take a look at it.
It's a decent installation but it's missing backflow protection and a mixing device.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
That's why I'm asking. I'm not one of these people that likes to shout out his opinion on the internet. I'd like to know the facts before I make a comment to the concerned parties.
I did. It's a decent-looking installation but it's missing backflow protection and a mixing device.
If it's code, I have to call the installing plumber and tell him he's got to go back.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
It's Town by Town on LI
And they are not on the same page all the time. Amagansett is in Town of East Hampton, I can't say for certain what they require but it is code in all the towns I am familiar with.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
There is no "Long Island" code.
As Robert suggested, it's town by town. You'll need to contact the inspector. Speaking of which, was the work inspected?0 -
Not that easy out here
John,I worked in the city for 15yrs.The one thing I never understood when I moved out to Long Island was the B/S you have to go through.The amount of areas that require different licenses and how the codes are different in many towns.Whenever I am unsure I always call plumbing dept and you will get an answer from a inspector.Call the town at 7.30 am that is usually when you can get them.It amazes me why there cant be either a county license or Ny license excluding the five boroughs as we all know the real challenging plumbing is done in the city.I understand your frustrations but I think the only way you will know is to call inspector.(even though you know the answer).But again if it is code the plumber has to go back and do right.0 -
Amagansett:
I have a daughter that lives in Amagansett. She built a new house a few years ago. It was the first place I ever saw an oil tank vent and fill piped with copper tube. DWV copper tube. It seemed to be sort of wild west territory way out there.
There was a BFD on the boiler. The house is on a well.0 -
Thank you for your replies.
I'm going to give the Town a call.
Best to all,
JohnContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
