owner
taco
Member Posts: 3
I have a steam boiler that goes up to five pounds pressure and shuts boiler off for one hour befor it relieves pressure back to turn boiler back on.
Need a lot more information to be helpful
but if that's a residential boiler there is something really wrong with the controls. If it were mine I wouldn't operate it until I found out a lot more about it and fixed the problems.Br. Jamie, osb
Off on safety for an hour
It is probably not the pressuretrol which is keeping off the boiler for an hour. More likely it is the LWCO, or another safety. A little troubleshooting with a multimeter should show which safety is responsible. When the flame cuts out, the steam collapses, developing a vacuum, which could hold water up in the returns for that length of time, starving the boiler of its water.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
