Expanion rate
What is the expansion of the copper lines in a horizontal run 100' long, of 1 5/8" copper discharge line and 1 1/8 liquid line? In inches, please. Ok ,I'll settle for the expansion rate if need be.
    Jamie Hall Member Posts: 27,285
    very nearly
    10 microinches per inch per degree F temperature change.  Depends a little on the alloy.
  • meplumber
    meplumber Member Posts: 673
    Rule of thumb.
    Terry, the rule of thumb that we have been using for AC and Refrigeration is 1" per 100' of horizontal run, properly supported.  It isn't as exact as Jamie's number, but hasn't bitten me in the rear yet.  I will do an expansion loop only if the horizontal run exceeds 150' and it is a heat pump application.  In AC only, the temp rise is below the point where it will cause a sufficient expansion to stress the joint.
    Good Luck.
  • Techman
    Techman Member Posts: 2,143
    Expansion
    Thanks Jamie, using your formula, I was closing in on that 1" # that meplumber provided.  Yup ,pretty darn close.
