Water Towers
Techman
Member Posts: 2,143
Can y'all recommend a few good books on the basics and advanced info on open and closed water towers? Thanks!
Water Towers
Terry, are you talking about Cooling Towers for water source systems?
If so, I have a PDF of a CEU seminar that I took in 2012. It was too basic for me, but I have given it to some of my younger techs and they learned some stuff.
If you want it, I can email it to you.0 -
Cooling towers/water towers
Morning, yes on CT/WT and yes on please send me any info that you have. Thanks meplumber!0 -
I want one:
Could you send me a copy too?
I have a lot of holes in my old brain that I'm trying to keep filled up with basic information. I've nothing better to do now.0 -
tagalong
Count me in too please for the pdf.
Thanks!:NYplumber:0 -
Also interested
is this something Dan could post on the Wall?0 -
PDF
I don't mind, but I don't know if it is copyrighted or not.0 -
Also interested.
Pass a copy my way if you will.
Harvey0 -
Pdf
Here it is. I apologize in advance is this is copyrighted by anyone.
I hope this works.0 -
CoolingTowers
Thanks meplumber, first card in the deck was Delta Cooling Tower, they kindly sent me a "White Paper" article, 8pages, on "Cold Weather Operation of Cooling Towers". the next card in the deck was Marley, now SXP Cooling-Marley. They have a library that has the very same "CWOCT" as above. They also have 36 more "White Paper" articles to pick thru. So for those interested, see you at the library. Next card will be Balitmore Air Coil. Not quiet the book I was looking for , but ,not bad, not bad! Now MY 1st source of info on COOLING TOWERS is RSES Educational Organization its in their SAM-Service Application Manuals-Manuals. Dividers 13-14-15.0 -
worth the extra cost
Closed circuit cooler is much better than open cooling tower over the long run. Sometimes a dry cooler makes the most economic sense.0 -
As usual, it depends
our here in the land of 5-10% humidity, evaporation can truly work wonders.0 -
yes it depends
In addition to what SWEI says,it depends on water & sewerage rates. Are there any districts that waive sewer fees for evaporated water? Avid gardeners should put a meter on their hose bib and try to get money back as well.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
