Painting Cast Iron Baseboard Radiator – Baseray/Governale
docancho
Member Posts: 38
Per instructions from US Boiler Company about painting Baseray baseboard:
PAINTING – BASE-RAY and Trip are primed with a latex (water based) paint and must be top coated with a high grade oil or solvent based enamel to prevent rusting of the metals…
I plan to use “Rust-Oleum Stops Rust Flat White Protective Enamel Paint”.
Do you think I would need High Heat paint or this one would do? I am using hot water heating with baseboards.
Also, any suggestions to use can & brush or spray paint?
Pls chime in with your thoughts.
depends if...
depends if you have steam or hot water. Steam requires high heat paint or it will blister off within an hour.0 -
hot water
Thanks.0 -
Baseboard Paint
I painted my Burnham baseboards with Benjamin Moore Impervo, it is an alkyd enamel paint. I used a brush to apply the paint.0 -
satisfied?
how long ago have you
painted and are you satisfied that you used Benjamin Moore Impervo?
Thanks.0 -
I paint
my steam radiators with Benjamin Moore flat acrylic enamels -- same stuff I use on the walls (in fact, right out of the same can...).
Unlike Eric's experience, most of them were done in the time frame of 8 to 10 years ago, and I have not experienced any rusting, peeling, flaking, blistering or other problems.
But that is a very high quality acrylic...Br. Jamie, osb
Impervo
I painted them 3 years ago and have been satisfied with the results.0 -
Paint
I just reconditioned a steam radiator for one of my customers. Sandblasted it clean of three layers of paint and primed it with Duplicolor Hot Rod Gray engine paint from my local NAPA. Figure this...those three layers were old oil based paint probably from a hardware store back when. We have alot of resources today for hi-temp paint. Hopefully you live in a state were there are no paint restrictions. You should be able to locate your color of choice or even try on-line at Summit Racing where they have numerous brands of good quality hi-temp engine paint.0 -
High Heat paint?
Since its hot water heating, I do not think high heat paint is required.
I keep water temperature in boiler at 180-190 degrees and high quality oil based should be able to withstand.
I read that fellow members use also non-high heat paint and do not have any issues with it. key part is that cannot be standard but high quality paint.0 -
Hmmm
The manufacturer recommends oil over latex primer? I'm not a painter, but that sounds like a recipe for disaster to me. I was told, long ago, that the oil would eat up the water-base.0 -
Oil Base
As well, with oil base paint your house will smell awful and probably off-gas when heated.
Rob0 -
Impervo
would you recommend I use High Gloss or Satin finish?
my thought is High Gloss might be easier to clean, maintain, etc.0
- 87K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
