Burnham Alpine
2»
  • gennady
    gennady Member Posts: 840
    alpine 210
    is it multi family building? 210.00btuhr?
  • John Mills_5
    John Mills_5 Member Posts: 952
    PVC pipes
    Did I understand that you are running the exhaust up the chimney as a chase but the intake out the basement wall? Not sure about boilers but many forced air furnaces won't run that way. Both pipes have to be in the same pressure zone, in other words - together.
  • gennady
    Venting
    You can do it with boilers, just pipe within the chimney must be supported every 5 feet.
  • Jim50
    Jim50 Member Posts: 1
    Alpine
    Piping venting and system pump needs to be by the book they run and save you lots on fuel
  • skisk8r
    skisk8r Member Posts: 2
    I have an Alpine 150 installed about 6 years ago. I recently noticed that the display screen on the front of the unit, although lit up, is not operating. The display is frozen and will not show any change as the furnace continues to operate normally. The touch screen is frozen and will not respond when touched. I checked the connections to the screen and from the internal workings (Sage 2?). Any thoughts?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Start a new thread for this, so your question will not get lost!--NBC
