Thermo couples
GTD
Member Posts: 33
in Gas Heating
I have a utica gas hot water boiler, model #M75AGB, serial # BB04404. What could cause the thermo couple to not work? I had to replace it three times since december. Any help would be great. Tom
how large is the pilot?
is this a standing pilot boiler or spark ignition?Cost is what you spend , value is what you get.
cell # 413-841-6726
thermo couples
It is a standing pilot boiler>0 -
too large of a pilot flame
or thermocouple too deep into the flame because something got bent can cause issues. are you sure it is the thermocouple that is the problem?Cost is what you spend , value is what you get.
cell # 413-841-6726
Thermo couples
Yes because i try to clean it will not light, i change it all is fine for a few months , then it will not light.0 -
Thermocouple
I seriously doubt that you encountered that many bad t'couples.You need a Millivolt meter to test how much electricity( volts ) is being produced by the pilot flame.0 -
Thermo couples
Thanks everyone for the help. Tom0 -
It is a thermo couple not
a thermo pile, right?Cost is what you spend , value is what you get.
cell # 413-841-6726
Thermo couples
It is a thermo couples.0 -
GTD do you have
a multi-meter that will measure millivolts? If so then go up and click resources, then library and look for Tims closet there is a procedure for checking thermocouples there.0 -
Thermo couples
Tim thank you for the info. Tom0 -
Tom, the
Utica boiler has a tendency to burn up thermocouples especially when it is cold and the boiler is running a lot. There is a thermocouple from Johnson (now Baso Gas Controls LLC) it is the K16LRA nickel plated corrosion resistant and hi-temp thermocouple. It is a little more expensive but it will out last most T'couples 3 to 1.0 -
Thermo couples
Tim , thank you.0 -
chimney?
If the chimney is not venting properly, it can spill CO2, which displaces O2 causing pilots to snuff out.0
- 123 Chimneys & Flues
