Heat
Andrew boiler
Member Posts: 44
How long will it take to heat my room up?
I have the master bedroom.
It's at 66 I am home now and what should I turn thermostat at?
Perfect temperature
Put another sweater on, and leave the temperature at 66 degrees all the time, to reduce global warming.--NBC0 -
Depends a little
on who else is in there with you, eh?Br. Jamie, osb
How Long?
About as long as it takes to cool mine.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 120 Geothermal
