is there any law for
magic90015
Member Posts: 26
hi.
I was wondering,
is there a plumbing law for apartment complex where
the heating pipe should be installed near by wall support or ceiling?
I just found my apartment complex has many wall suppor and ceiling nearby that makes the raddling banging noise.
If so where can I find the document online?
Thank you
I was wondering,
Thank you
There should
be a law against raddling banging noises. It drives me into a fit of uncontrollable rage every time.
If you could be a little more specific we might be able to help you. Wall supports, ceilings and heat pipes don't give us a lot to go on.
Harvey0 -
just want to find the plumbing code
i fixed the noise. but it seems the basement in this apartment installed so many wall support, ceiling nearby heat pipe and heat pipe isn't still also. and there's lot of gap in wall that also makes the heat pipe hit the wall to cause the raddling banging noise. I did find plumbing handbook online that says don't put heat pipe too close to wall or ceiling but trying to find the state law or plumbing building law that's against this cause of the raddling noise.0 -
Law:
There isn't any law.
Pipes that rattle are the result of poor installation by hackaroos.0 -
Yeah, there's a law...
It's called common sense. A lot of folks live in constant violation of that law.
Other than support methods and intervals, the is no specific law.Bob Boan
Plumbing codes
are considered law, at least here in Colorado. Inspectors have badges. Both the IPCC and UPC define piping supports floor to floor and in horizantal intervals, but they are not defined enough to prevent rattling per say. Most of my inspectors will grab and shake, and gig us on a bang. But then I want no warranty issues, so I go the extra mile. With plumbing sudden-off valves require shock arrestors, which helps.
But mostly it is a case of how much integrity the contractor brings. Many have the 'if you ain't cheating, you ain't trying' mentality. More 'laws' never help anything; what is needed is more information out for the consumer to know who the good guys and why they matter; and that you usually DON'T get what you DON'T pay for.0
- 167 Indoor-Air Quality
