Why brass?
mgmine
Member Posts: 58
In this link concerning hooking up a vaporstat it says to use brass fittings. Why? Would it be to stop a galvanic reaction or for some other reason.
<a href="http://www.heatinghelp.com/files/posts/14911/Low%20Pressure%20Gauge%20Piping%20-%20%20Bill%20of%20Materials.pdf">http://www.heatinghelp.com/files/posts/14911/Low%20Pressure%20Gauge%20Piping%20-%20%20Bill%20of%20Materials.pdf</a>
Brass or bronze? Union?
I see that actually say bronze...I bought mine brass. Is that OK. Also, I put unions at both the top AND bottom of the pigtail thinking I could take off both controls and not have to worry about removing the pigtail. Is the illustration a way better way?Two-pipe Trane vaporvacuum system; 1466 edr
Brass or bronze...
but I don't think I've ever seen a bronze pigtail; it's usually red brass.
And the reason isn't a galvanic reaction problem, it's that iron will rust and plugs up much more quickly and is harder to clean.
Unions? I love them. Makes life so much simpler...Br. Jamie, osb
- 50 Industry Classes
