Plumber
Lu
Member Posts: 1
Hi I have problem with a hot water heating system it has honeywell zone valves and one of them are banging or a hammer effect when it closes .
Any solutions .
Any solutions .
Backwards
First thing to check is the arrow on the side and the arrow on the circulator. They should be going in the same direction.
A picture would help.
Albert Einstein0
