adding radiant loop - hot water coil?
hey guys-
I haven't been around for a bit.  Installed my own Smith G8 with Carlin EZ gas burner last year, and i've been basking in the heat since :-)
i'm thinking of adding a radiant zone to my house.  I have available BTUs.
What's the consensus, can i design it using a hot water coil?  Is that common practice?
  • H3809
    H3809 Member Posts: 19
    Here is what I got
    I have Everhot tank feeding hot water tank 2 hot water baseboard zones, eventually one will turn radiant. (at the time of picture I only have 1 hot water baseboard zone in)
  • TomM
    TomM Posts: 233
    looks great man
    what size pump are you running?
    if i use the smith 'tankless coil', i can get 1.75gpm continuous feed from it.
    off the cuff, that would equate to about 17,000BTUs, of which i have in my boiler.
    If i were to change the firing, i could get 2.0gpm.  This would be enough to heat the two small rooms that i want to heat.  I'm not doing a radiant floor, i would be using Euro wall radiators.
    I'm just wondering why i see lots of Everhot tanks, and i never see anybody using their tankless coils for radiant.  Is there a problem with that?
  • Mark N
    Mark N Member Posts: 1,146
    Radiant Loop
    Do a site search for "condensate hot water heating FAQ" read the article.
