adding radiant loop - hot water coil?
TomM
hey guys-
I haven't been around for a bit. Installed my own Smith G8 with Carlin EZ gas burner last year, and i've been basking in the heat since :-)
i'm thinking of adding a radiant zone to my house. I have available BTUs.
What's the consensus, can i design it using a hot water coil? Is that common practice?
looks great man
what size pump are you running?
if i use the smith 'tankless coil', i can get 1.75gpm continuous feed from it.
off the cuff, that would equate to about 17,000BTUs, of which i have in my boiler.
If i were to change the firing, i could get 2.0gpm. This would be enough to heat the two small rooms that i want to heat. I'm not doing a radiant floor, i would be using Euro wall radiators.
I'm just wondering why i see lots of Everhot tanks, and i never see anybody using their tankless coils for radiant. Is there a problem with that?There was an error rendering this rich post.
Radiant Loop
Do a site search for "condensate hot water heating FAQ" read the article.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
