adding radiant loop - hot water coil?
TomM
hey guys-
I haven't been around for a bit. Installed my own Smith G8 with Carlin EZ gas burner last year, and i've been basking in the heat since :-)
i'm thinking of adding a radiant zone to my house. I have available BTUs.
What's the consensus, can i design it using a hot water coil? Is that common practice?
looks great man
what size pump are you running?
if i use the smith 'tankless coil', i can get 1.75gpm continuous feed from it.
off the cuff, that would equate to about 17,000BTUs, of which i have in my boiler.
If i were to change the firing, i could get 2.0gpm. This would be enough to heat the two small rooms that i want to heat. I'm not doing a radiant floor, i would be using Euro wall radiators.
I'm just wondering why i see lots of Everhot tanks, and i never see anybody using their tankless coils for radiant. Is there a problem with that?There was an error rendering this rich post.
Radiant Loop
Do a site search for "condensate hot water heating FAQ" read the article.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
