Problem with fuse socket on Buderus GB142 UBA3
LAG1VT
LAG1VT Member Posts: 9
Repair part for Buderus GB142 UBA 3
Hi ,
I have a UBA 3 V3.6 for a Buderus GB142 that needs to be repaired. The entire fuse socket
dropped down inside the enclosure when trying to replace the fuse. Is
there any way I can get a replacement part? The socket appears to just
push into the housing and make contact with the circuit board. That
is, there are no wires actually attached to the fuse socket that I can
see. Possibly someone out there that has replaced an old UBA V3.5 with
the V3.6 still has the 3.5 laying around. I would assume the fuse socket
is the same.
If anyone can help let me know.
  • Mpj
    Mpj Member Posts: 109
    UBA
    I have a broken (malfunctioning) UBA3.6 that I replaced about three weeks ago, your welcome to it.
  • LAG1VT
    Thank You, Thank You, Thank You
    That is fantastic. How best for you to reach me and get shipping information? Is it okay to put  an e-mail address in one of these replies?
  • Zman
    Zman Member Posts: 7,611
    Contact
    You have likely already figured this out. Click "contact this user" under their name
    Albert Einstein
  • LAG1VT
    Contact
    Yea I figured it out. Thanks for the recommendation to put my post on the Main Wall.
  • Mpj
    UBA
    LAG1VT, I just sent an email to you. MPJ
  • LAG1VT
    UBA
    Mpj,
     Got your e-mail and responded. Still need the UBA
  • jguinta
    jguinta Member Posts: 12
    Where should I go to buy a new UBA3? Is Buderus selling the UBA ?
