Problem with fuse socket on Buderus GB142 UBA3
LAG1VT
Member Posts: 9
Repair part for Buderus GB142 UBA 3
Hi ,
I have a UBA 3 V3.6 for a Buderus GB142 that needs to be repaired. The entire fuse socket
dropped down inside the enclosure when trying to replace the fuse. Is
there any way I can get a replacement part? The socket appears to just
push into the housing and make contact with the circuit board. That
is, there are no wires actually attached to the fuse socket that I can
see. Possibly someone out there that has replaced an old UBA V3.5 with
the V3.6 still has the 3.5 laying around. I would assume the fuse socket
is the same.
If anyone can help let me know.
Hi ,
is the same.
UBA
I have a broken (malfunctioning) UBA3.6 that I replaced about three weeks ago, your welcome to it.0 -
Thank You, Thank You, Thank You
That is fantastic. How best for you to reach me and get shipping information? Is it okay to put an e-mail address in one of these replies?0 -
Contact
You have likely already figured this out. Click "contact this user" under their name"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Contact
Yea I figured it out. Thanks for the recommendation to put my post on the Main Wall.0 -
UBA
LAG1VT, I just sent an email to you. MPJ0 -
UBA
Mpj,
Got your e-mail and responded. Still need the UBA0 -
Where should I go to buy a new UBA3? Is Buderus selling the UBA ?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
