Repair part for Buderus GB142 UBA 3
Hi ,
I have a UBA 3  V3.6 for a Buderus GB142  that needs to be repaired. The entire fuse socket
dropped down inside the enclosure when trying to replace the fuse. Is
there any way I can get a replacement part? The socket appears to just
push into the housing and make contact with the  circuit board.  That
is, there are no wires actually attached to the fuse socket that I can
see.  Possibly someone out there that has replaced an old UBA V3.5 with
the V3.6 still has the 3.5 laying around. I would assume the fuse socket
is the same.
If anyone can help let me know.
  • Zman
    Zman Posts: 7,614
    edited January 2014
    Parts
    It looks like there is a part number for that in the manual. Why not call your local dealer and order one up.
    http://www.buderus.us/files/201301031745390.GB142_InstallationInstructions_en_72150200_11-11.2012.pdf
    It looks like part number 38345
    Carl
    Albert Einstein
  • LAG1VT
    LAG1VT Posts: 9
    Thanks for the help
    Carl,
    Part number 38345 is the "fuse holder". I have that part. Problem is the fuse holder (PN: 38345) plugs into a receptacle  in  the casing. The receptacle  is missing and there is no part number showing for this part.
    When I was inserting the fuse holder  the receptacle literally  pushed in and dropped inside the box.
    Larry
  • Zman
    Zman Posts: 7,614
    Buderus
    Larry,
    Either way this sounds like either a superglue repair or a call to Buderus.
    You could try posting this on the main wall. I am sure you are not the first person to have this problem. Sometimes these subcategories get overlooked.
    Carl
    Albert Einstein
