Repair part for Buderus GB142 UBA 3
LAG1VT
Member Posts: 9
Hi ,
I have a UBA 3 V3.6 for a Buderus GB142 that needs to be repaired. The entire fuse socket
dropped down inside the enclosure when trying to replace the fuse. Is
there any way I can get a replacement part? The socket appears to just
push into the housing and make contact with the circuit board. That
is, there are no wires actually attached to the fuse socket that I can
see. Possibly someone out there that has replaced an old UBA V3.5 with
the V3.6 still has the 3.5 laying around. I would assume the fuse socket
is the same.
If anyone can help let me know.
is the same.
Parts
It looks like there is a part number for that in the manual. Why not call your local dealer and order one up.
http://www.buderus.us/files/201301031745390.GB142_InstallationInstructions_en_72150200_11-11.2012.pdf
It looks like part number 38345
Albert Einstein0 -
Thanks for the help
Carl,
Part number 38345 is the "fuse holder". I have that part. Problem is the fuse holder (PN: 38345) plugs into a receptacle in the casing. The receptacle is missing and there is no part number showing for this part.
When I was inserting the fuse holder the receptacle literally pushed in and dropped inside the box.
Larry0 -
Buderus
Larry,
Either way this sounds like either a superglue repair or a call to Buderus.
You could try posting this on the main wall. I am sure you are not the first person to have this problem. Sometimes these subcategories get overlooked.
Albert Einstein0
