Boiler help
Repaifarm
Member Posts: 2
I am new to this site so if I am doing something wrong please tell me. I was referred to this site by an Ag forum.
We are planning on building a new house shop combination the house will be 30 x 50 with a 30 x 30 garage that will be built into a 100 x 120' with 20 foot sidewalls shop. There will be living quarters above the garage. We are planning on using spray foam insulation and am thinking it will be steel construction. The shop will have 2 - 20 x 18 overhead doors with a swing outpost on one and and a 16 x14 foot overhead door on the other end. We would like have in floor heat.
We have a very good supply of corncobs sawdust and wood chips and would like to heat this building with a boiler that is outside of the building we would like to have this boiler have a stoker like the old coal furnace So can you help me out with information? I have searched the Internet and think there is one that might work in West Virginia but that is a long ways away from South Dakota.
If you have any questions you can contact me at <a href="mailto:repairmarm@gmail.com">repairmarm@gmail.com</a>
There will be lots of questions, but see what we can do
First off -- radiant floors (your in floor heat) are probably a good choice. Would these be concrete floors? Or would it be wood floors with the radiation stapled up beneath (and then insulated!). Makes a difference.
The first thing to do though, is to sketch out your floor plans and what's where, and figure out what your heat loss will be. There are several programs available to do that. Ideally, you will do it on a space by space basis, so that later when you design the heating you can decide just how much heat goes into which spaces, to keep them the way you want them.
But the overall heat loss is the most important factor. Once you have that, you can begin really looking for outdoor boilers such as you mention. They do exist -- but they are a little rare.Br. Jamie, osb
boiler help
The house and shop will be concrete floors the living quarters above the garage will be wood floors. I would like all tile floors in the house but my half to give in and have carpet in the bedrooms and living room.I am thinking either baseboard heaters or a air handler for the living quarters above the garage.0 -
Start Here
Sign up for Taco's FloPro University. It's free, and they have online tutorials that guide you through the process, start to finish. It will be much easier, if you understand exactly what is involved.I think you'll find the process fascinating, and enjoy the tutorials. Once you have absorbed as much of that information as possible, there are other resources that are more specific to your situation, but these are the building blocks you need first. http://www.taco-hvac.com/0
