Heat
How long will my heat to warm up to 75?
It's at 65
  • unclejohn
    unclejohn Member Posts: 1,833
    Normally About
    8 to 10 feet.
  • Zman
    Zman Member Posts: 7,609
    Heat
    Are we talking about an actual measured temp or your perceived temp on a given day.
    Temperature is an actual scientific measurement. In your pasts posts you have indicated you beleive otherwise. I think the first step is admitting that you like the house warm, real warm.
    No one can tell you how long it will take without a ton of details.It will vary a bit based on outdoor temp. You could just time how long it takes and go from there.
    Carl
    Albert Einstein
  • icesailor
    icesailor Member Posts: 7,260
    How quickly:
    It depends on how cold it is outside, and if you have a lot of excess radiation (in which case it will be quickly) or not a lot, if any excess radiation. In which case, it will take considerably longer. If you don't have enough radiation, it may NEVER get to 75 degrees.
    So, I guess we could say, "It depends". On things.
  • Paul48
    Paul48 Member Posts: 4,469
    Hmmm
    My boss likes to ask me, "How long is it going to take to do that?" My response is usually."Just until it's done". The list of unknown factors that would affect the answer to your question, could take up a wing in the Library of Congress.
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    My house
    uses metric. It usually takes my heat about 3 meters till I'm warm.
  • Funny You Ask That
    Last night I turned down a slab radiant zone to 65 degrees, this morning I turned it up to 75 degrees and it took just over 2 hours. I have close pipe spacing, and a really well insulated slab, but it really surprised me because it was about 14 degrees outside. This customer is going to go with set back, even though it is a slab, because of the quick recovery time.
    Thanks, Bob Gagnon
