Pex Expansion without tool?
WoNHUSA
Member Posts: 34
I am a homeowner installing my my own Pex for a new heating system. I will be installing radiant panels for two rooms. With the parts I have, I will need to make only 4 expansion connections with the Pex. I can't find an expansion tool at any of the local tool rental sites, and don't really want to have to buy a $350 tool to make the 4 connections.
Is the a way to expand the Pex and fitting with some sort of an inexpensive tool, device or "homemade" expansion tool? Thanks for any help.
Compression fittings
You don't have to use expansion fittings. If you elect to use the expansion type, you will need the tool.
If I were you, I would use compression fittings.
Shark bite and crimp fittings would also be an option.
Albert Einstein0 -
Can I use different tubing?
The Pex for the radiant is hePex, which I guess if supposed to be used with the aluminum panels. The outside diameter of the 1/2" hePex is the same as 1/2" oxygen barrier pex that is used with a crimp installation tool (which I have).
Is it okay not to use the hePex in the Uponor Joist Trak panels? It would be easier to use the 1/2" crimp fitting tubing (Mr. Pex Oxygen Barrier is what I have compared to the hePex).0 -
PEXes
Uponor hePEX and Mr. PEX tubing are both made from PEX-A resin, and are therefore compatible with all types of PEX fittings.
For the record, PEX-B and PEX-C resins are only compatible with crimp fittings (do not use them with with expansion fitings.)0 -
Thanks for the info...Can I use the Mr. Pex type a Oxygen barrier in the Joist Trak? The Mr. Pex is compression fitting and the Uponor hePex is expansion and I do not have that tool and it is pricey for the 4 fittings I need to make.0 -
PEX tubing
as long as it's SDR9 PEX, it will work in Joist-Trak. Both Mr. PEX and Uponor have non-slip coatings on their exterior which help minimize expansion noise. Not sure about other brands.0 -
Watts Al-Pex
uses 2 kinds of compression fittings, wrench-able and crimp; often the supplier you get it from lends you the crimp tool.
I've used the brass Cash-Acme crimp fittings for Wirsbo HePex before too.0
