Location of pigtail relative to boiler water lune
cdm
cdm Member Posts: 77
My pigtail is presently located so that 1/2 the loop is at the mid sight glass waterline. Can the pigtail be moved to above the top of the sight glass?
thanks -cdm-
    Jamie Hall Member Posts: 26,835
    Sure --
    it should be measuring steam, not water, anyway.
    That is, sure -- if you have a handy dandy tapping to hook it into.  Otherwise it could be difficult...
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    Yes
    It wouldn't be a bad idea if you can find a convenient tapping. I have mine connected to branches off of the upper gaugecock tapping, so they are completely above the water line.
    Since they're high and dry, you need to manually fill the traps with water.
  • cdm
    Location of pigtail relative to boiler water line
    Thanks guys - This will make my re-installation easier and neater.
    -cdm-
  • Hap_Hazzard
    By the way...
    Note the union under the Pressuretrol. Highly recommended. You'll thank yourself later.
