Volume of water per inch of height in gauge glass (Burnham)?
BoBoBoB
BoBoBoB Member Posts: 17
I've got a Burnham Independence PIN-5. I don't have a counter/meter on the feed. Does anyone know how much water corresponds to an inch of height in the gauge glass?
In other words, if the water line drops 1" below NWL, how much water have I lost (in gallons)?
  • Paul48
    Paul48 Member Posts: 4,469
    Drain
    the boiler until the water drops an inch in the sight=glass, and see how much that is.Use a bucket.
    Jamie Hall Member Posts: 25,856
    And I might point out
    that the free water surface area of the boiler -- almost any boiler -- is different at different elevations on the gauge glass -- so an inch of water at the top of the glass may be a very different amount of water than an inch at the bottom of the glass.
    As Paul said, use a bucket.  Better yet, get a feeder with a water meter on it.
  • BoBoBoB
    Bucket
    Drain and measure--duh!
    Thanks. I'll give it a shot sometime soon.
  • EzzyT
    EzzyT Member Posts: 1,366
    good water feeder
    hydrolevel vxt water metered feeder is a great product they make them in 24 volts or 120 volts
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • BoBoBoB
    I'm cheap
    I get that an auto water feeder is good insurance if you're away, but otherwise it's $200 plus installation, plus the worry that it fails. I'll put a couple calibrated marks on the glass and keep a log book instead of the time being.
  • BobC
    BobC Member Posts: 5,521
    thats what I do
    When I had oil I would record the elapsed time meter every day and make a note if I added water (1-8-14  1/2" water ). The elapsed time meter allowed me to track my oil usage and it made up for the fact the gauge on the tank had been broken for a decade. When i called for an oil delivery I was never off by more than a couple of gallons on the amount of oil it would take to fill the tank.
    Now with gas I still keep a log to track any observations about the system. Just make damn sure the LWCO works.
    Bob
    3PSI gauge
