Thermostat
I think I need a new thermostat any ideas what is going on?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Reset button?
    Look for a reset button somewhere on or in it. A call to tech support might give you the information.
    Could the thermostat have been exposed to a static electricity shock when you were changing the settings?--NBC
  • conversiontime
    conversiontime Member Posts: 87
    probably toast
    Had a Rite Temp (name?)that did something similar but not to that degree. Assumed it was the underlying cheap chinese board as pushing on the screen would sometimes fix it. Towards the end the thermostat started doing all kind of craziness and would not consistently fire the boiler and often the screen was be similar to yours with ghost images everywhere.
    Jamie Hall Member Posts: 26,838
    I think
    it's modern art...
    Also toast.
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    tstat
    It is probably toast but try removing it from the wires and then remove the batteries for ten minutes. then reinstall the batteries.
