Whoa - one for the record books
Le John
Le John Member Posts: 250
Today is the coldest day NYC has seen in more than 118 years.
Time to install a mod/con
  • Gordy
    Gordy Member Posts: 9,546
    You all
    Are just spoiled;-)
    Here in Northern Illinois about every 10 years we get a sharp double below design week. We were due. But I have never seen the warning map cover almost 1/3 of the country north south east and west before.
  • Paul48
    Paul48 Member Posts: 4,469
    Soft
    We rely on a lot of things to survive. City-folk are the worst offenders, myself included. Most won't even spend the few dollars to buy a generator large enough to power the boiler, by itself. Imagine how hard a life-style it was 200 years ago.If you didnt cut enough wood for the winter....you died.
  • SWEI
    SWEI Member Posts: 7,348
    We really are
    If you get a chance, watch this http://www.pbs.org/wnet/frontierhouse/
  • Mark N
    Mark N Member Posts: 1,144
    Get facts straight
    Today is the coldest January 7th in 118 years.
  • ttekushan_3
    ttekushan_3 Member Posts: 964
    mod/con
    but on a below design day, would it MOD? Would it CON?
    Terry T
  • Gordy
    edited January 2014
    Creatures of comfort
    Is what we have a,ways been, and always will be . Humans have spent generations upon generations inventing widgets to make life more convenient and comfortable. It is evolution, but the trick to survive is not to forget how the stepping stones worked getting here in case you ever have to back track.
  • SWEI
    Will it?
    It should MOD to 100%.  Assuming it was sized to the heat loss calculation, it will easily meet the demand.
    It will CON if the emitter system was designed for that.
  • JohnNY
    JohnNY Member Posts: 3,341
    Coldest day?
    Give me the simplest cast iron boiler you got with a standing pilot, no vent damper, and a T87.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Mine still condenses above a return of 140
    And I know it's not a leak in the HXer because the make up is off.
    Combustion analysis shows 86 to 88% at 170 degrees F. And it still modulates down even at design conditions, and I undersized it by 50%. (load said 100K, installed a 50K). I would NEVER do that for a customer, but it is my home and I can experiment there without creating any issues. Makes you wonder about heat loss programs in general though...
    ME
    Jamie Hall Member Posts: 26,840
    I'll buy it...
    Keep It Simple, Stupid has a lot to be said for it when the going gets tough...
  • Le John
    Yeah
    Oops, I see what I was thinking was not what I wrote.
    Thanks for the clarification.
  • STEVEusaPA
    22 degrees
    Anyone else besides me in the Northeast find it odd to be happy that the temp is back up to 22? Yeah I know you New Englanders had it worse, and colder for longer periods of time.
