radiator enclosers/efficency
Hollis
Member Posts: 105
I am having a discussion with someone that says that radiator enclosures decrease efficiency and will make fuel costs go up.
However I'm thinking that yes it make take longer for the heat to rise but if you have an enclosed space,...meaning the house, that the same amount of Btu's will be delivered to heat it. The house in question is an old building with a new boiler and its two pipe steam. Reflectors on back of any radiators on outside walls. The fuel bills seem very good with the enclosures in place. Would it be any better in the long run if they were removed?
Design Is Everything
First of all, you are correct in saying that enclosures don't affect efficiency. Your reasoning is exactly right. But there is efficiency and there is effectiveness. For example, a small radiator is just as efficient as a larger one, but it won't heat the same space as effectively as a larger one. It can't condense as much steam and give off as much heat in the same amount of time. A radiator enclosure can either enhance or reduce the effectiveness of a radiator. It's all in the design.
If you're interested, there are several articles in the Library on radiator enclosures.Just another DIYer | King of Prussia, PA
Enclosure
Radiator enclosures will either increase or decrease the amount of heat that ends up in the room Depends on design. A poorly designed enclose can trap the heat in the enclosure. Not very efficient to pay all that money to heat the inside of a box.0 -
Why enclose?
With the exception of original architectural radiator enclosures, seats, grates, etc., I would have to say that I have never seen a radiator enclosure that I thought looked better than a bare radiator. The enclosures are usually bulky and large and take up more space than the radiator alone.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Greening steam
Holohan's book discusses this subject. I like enclosures with moveable louvers because it's the best way to control heat output in each room. Besides which, nowadays somebody will bare his bottom,sit on a radiator, and then sue the beegeesuss out of you.0 -
From Gerry Gill's business websiTe
a very informative site if you have time.
http://www.gwgillplumbingandheating.com/webapp/p/238/effect-of-radiator-covers0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
