radiator enclosers/efficency
Hollis
Hollis Member Posts: 105
I am having a discussion with someone that says that radiator enclosures decrease efficiency and will make fuel costs go up.
However I'm thinking that yes it make take longer for the heat to rise but if you have an enclosed space,...meaning the house, that the same amount of Btu's will be delivered to heat it. The house in question is an old building with a new boiler and its two pipe steam. Reflectors on back of any radiators on outside walls.  The fuel bills seem very good with the enclosures in place. Would it be any better in the long run if they were removed?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Design Is Everything
    First of all, you are correct in saying that enclosures don't affect efficiency. Your reasoning is exactly right. But there is efficiency and there is effectiveness. For example, a small radiator is just as efficient as a larger one, but it won't heat the same space as effectively as a larger one. It can't condense as much steam and give off as much heat in the same amount of time. A radiator enclosure can either enhance or reduce the effectiveness of a radiator. It's all in the design.
    If you're interested, there are several articles in the Library on radiator enclosures.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,389
    Enclosure
    Radiator enclosures will either increase or decrease the amount of heat that ends up in the room Depends on design. A poorly designed enclose can trap the heat in the enclosure. Not very efficient to pay all that money to heat the inside of a box.
  • Dave in QCA
    Dave in QCA Member Posts: 1,803
    Why enclose?
    With the exception of original architectural radiator enclosures, seats, grates, etc., I would have to say that I have never seen a radiator enclosure that I thought looked better than a bare radiator. The enclosures are usually bulky and large and take up more space than the radiator alone.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • jumper
    jumper Member Posts: 2,464
    Greening steam
    Holohan's book discusses this subject. I like enclosures with moveable louvers because it's the best way to control heat output in each room. Besides which, nowadays somebody will bare his bottom,sit on a radiator, and then sue the beegeesuss out of you.
  • Joe V_2
    Joe V_2 Member Posts: 233
    From Gerry Gill's business websiTe
    a very informative site if you have time.
    http://www.gwgillplumbingandheating.com/webapp/p/238/effect-of-radiator-covers
