Improper use of a Tee on Main?
Is it bad to have a Tee at the end of the Main? Going up is a riser and down is reduced for the wet return? If bad would you recommend using the T to add a small section to the Main and then an elbow for the Dry return at the very end?
    Jamie Hall Member Posts: 26,835
    Unless your steam is very wet indeed
    there's no good reason why that setup won't work just fine...
