Improper use of a Tee on Main?
itzasean
Member Posts: 71
Is it bad to have a Tee at the end of the Main? Going up is a riser and down is reduced for the wet return? If bad would you recommend using the T to add a small section to the Main and then an elbow for the Dry return at the very end?
Unless your steam is very wet indeed
there's no good reason why that setup won't work just fine...Br. Jamie, osb
- 114 Geothermal
