Buderus 6A
Mpj
Mpj Member Posts: 109
Hello All,
I have a GB that I looked at before Christmas it was giving a 6A code, the flame sensor was changed before I got there so I do not think that is the problem. I cleaned and serviced the boiler (it has not been serviced in a couple of years) still had the same problem. Checked everything in the manual and found nothing wrong. Called Buderus and spoke to a tech, he walked me through other tests. Found it to be the 24 volt transformer, changed the trans and all seemed good. Got a call tonight the 6A is back. Does anyone have the procedure to check the transformer? I'm thinking the new went bad.
  • BobC
    BobC Member Posts: 5,539
    Transformer
    It sounds like you might have an intermittent short somewhere, it could be a wire or any coil that runs off the 24v.
    If you can get to the transformer output leads (impossible if it's mounded on a printed circuit card) use a clip on amp meter to measure the current, compare that to the transformer rating. You could also put a fuse on the output of the transformer (fuses are cheaper than transformers).
    Bob
    3PSI gauge
  • Ironman
    Ironman Member Posts: 7,859
    Ignition Issue?
    Have you checked everything on the fuel and vent side? What's your incoming gas pressure? Is the condensate trap draining?
    The transformer diagnosis seems a litte stretched to me. Was the old one producing 24 volts?
    Bob Boan
  • Mpj
    6A
    Bob, I'm going to the job tomorrow AM, I do not understand what you mean by installing a fuse. What is the purpose of the fuse?
    Iron, The incoming gas pressure is 7.7"WC, set the gas/ratio to -0.03. The old transformer was reading about 19 volts.
  • Mpj
    6A
    Went back to the job today. It turned out to be the UBA. replaced it and all is well again.
    Thanks for all your help.
