SR 504 exp 4 zone switching relay
Toptree19
Toptree19 Member Posts: 1
I have base board heating and a gas boiler. The base boards are getting warm, but not warm enough to actual give off much heat. So I went down to the boiler to try and find a problem, the boiler is on, but the relay switch has both green (power) and red lights (all 3 zones). I am just trying to find out if these lights are supposed to be red or not, and if not what could be the cause. Thank you very much in advance.
  • unclejohn
    unclejohn Member Posts: 1,833
    The
    Green light normally means the vavle is powered and the red normally means it's fully open. Is the pump running?
  • Ironman
    Ironman Member Posts: 7,903
    SR504
    That's a pump control panel, not a zone valve panel. The green light means there's power to the panel and the red light indicates that zone is calling for heat.
    I doubt your problem is control related unless the aquastat is bad. I'd look on the hydronic side if the boilers getting hot. Air bound? Bad circ?
    Bob Boan
