Near boiler piping size??
Dave0176
Member Posts: 1,178
Getting ready to install a WM PEG 30. The EDR is 185 so the boiler is a bit oversize, but it's the smallest steamer. There are only 4 radiators in the house. The riser is piped to a bullhead tee, on one side there is 3 radiators the other is 1. Should I remove the tee and pipe separate mains. This system has been piped like this from day one, also the returns are piped into a tee and one drop. Usually I run 2 2" risers and a 2 1/2 header, would that be overkill for this system??
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Fact
Wouldn't be over-kill at all. The fact that it has been piped that way from day one just means a knucklehead installed it then. Did he put an arrow on the pipe, so the steam knows which way to go? Although small...the homeowner and the system deserve better.0 -
OK
Sounds good than. Getting tired of fixing steam system mistakes.lolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Forgot to mention
I will be running a drop header as I do on all my steam jobs.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
