Near boiler piping size??
Dave0176
Dave0176 Member Posts: 1,178
Getting ready to install a WM PEG 30. The EDR is 185 so the boiler is a bit oversize, but it's the smallest steamer. There are only 4 radiators in the house. The riser is piped to a bullhead tee, on one side there is 3 radiators the other is 1. Should I remove the tee and pipe separate mains. This system has been piped like this from day one, also the returns are piped into a tee and one drop. Usually I run 2 2" risers and a 2 1/2 header, would that be overkill for this system??
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
