One Pipe Boiler System to A Two Pipe
CG1981
Member Posts: 1
I am new here but I was looking at my heating system the other day and the person who I bought the house from put in a new TriangleTube boiler but it looks as if the piping was left in a one pipe configuration, is it worth my time to convert this to a two pipe system. There are 7 baseboard hot water radiators and the SqFt on the house is 1181. Please let mew know your thoughts and if this should be something a DIYer can do on my own. Thanks in advance.
1-pipe or 2-pipe?
Can you post some pictures, and describe your system in greater detail?
A lot of repairs, maintenance can be done by the homeowner, as long as he has the knowledge (from here).--NBC0 -
triangle tube does not make steam boilers
if the used one pipe you would be very cold.Cost is what you spend , value is what you get.
cell # 413-841-6726
1-pipe or 2-pipe
Maybe you are thinking of primary-secondary piping on a hot-water system?--NBC0 -
1-pipe
Monoflo?0 -
maybe
Series loop ? It would probably be a waste of time and money to convert something to two pipe system for no other reason than just doing it. Copper is pretty expensive these days.0 -
Monoflow
I agree that this sounds like a mono flow system.
If your monoflow is working, leave it alone. Most folks have trouble with monoflow when they attempt to modify. There is nothing inherently wrong or inefficient about monoflow.
I would be sure the outdoor reset is set up correctly, that is where the real efficiency comes from.
Carl
Albert Einstein0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
