one pipe steam
I have a one pipe steam heating system and two radiators on the second floor that just get to hot.I have been looking at these macon 1/8 inch steam vents that regulate temperature buy way of a thermostatic valve.The inlet piping is 1/1/2 and I really don't want to change the angle rad valve at the floor,im just not sure this little air vent valve is gonna do the job any thoughts? whats gonna work better? 1/1/2 thermostatic valve or this 1/8 inch thermostatic air vent valve
  • BobC
    BobC Posts: 5,576
    Is this the one your looking at?
    I assume your looking at this -
    http://www.tunstall-inc.com/wp-content/uploads/OPSK12041.pdf
    The way they work is to stop steam getting into the radiator by blocking the air from leaving the radiator. If the air can't leave the steam can't get in.
    What kind of air vents are on the radiators now? It might be worth trying Hoffman 40's first because they cost a lot less than a TRV does. If they still get too hot you can install the TRV's.
    Bob
    3PSI gauge
  • jumper
    jumper Posts: 2,607
    vent valve
    Air vent valve is the only one recommended for one pipe. You're not supposed to modulate the intake on a one pipe. That angle valve is strictly for full open or completely closed. There's thermostatic vent valves with an integrated vacuum break.
