No heat on second floor
Atype
Member Posts: 4
I bought a house back in March (forclosure). The house has 3 zones, 1st zone is the main first floor, the second is a first floor family room addition, and the third is the second floor.
Since day one the heat on the second floor never worked. Since winter is coming soon I decided to have it checked out. A plumber came and drained the system and replaced the head for the zone valve but its still not working. We found out that the supply and return lines run in exterior walls. The piping at the second floor when it enters the second floor is extremely hot but the temperature cools down quickly 10 ft into the run. The plumber thought the line was partially frozen and would eventually unblock but that hasnt been the case.
Any ideas?
Any ideas?
the system is air bounded
The plumber may not be a true hydronic heating guy.. you generally don't need to drain the whole system for just replacing the powerhead.. what we all need is for you to post some pictures of your boiler and near pipings and we'll go from there.0 -
No Circulation
What attempts have been made to bleed air from the zone?
You may well be frozen, if you are, you need to find a long term solution. The best plan is to move and or insulate the pipes. Glycol would be a less desirable plan.
The plumber should be able to power purge the zone to be sure it is frozen. If it is, you need to find a way to heat that section of pipe.
Albert Einstein0 -
pictures
pics added0 -
Circ flanges
Are a red flag they have been leaking for some time.
How long was the house in foreclosure?
Was the system drained to get through winter with out freezing pipes?
Or was heat maintained through the winter during foreclosure?
If the pipes did freeze in the wall be aware if it gets up and running for leaks. I would assume "plumber verified system holds pressure? 12 psi
Like I say IF the pipes are frozen, and that IS the reason there is no flow to second floor you may encounter system not holding fill pressure, and water damage from leaks in the wall. Just beware of those things.
It sounds like its air bound, but wondering if system worked before. Something you may never know. Unlikely it did not.0 -
forclosure
The house was forclosed for two years
The house was properly winterized during that time. The utilities were turned on and house dewinterized when I got my home inspection.
Im hoping I dont have to open up the wall of the room I just finished renovating.
If its air bound wouldnt draining the system fix it?0 -
Air
Air sure seems like the likely problem. The way the boiler is piped with the circulator pumping into the expansion tank makes the air harder to get rid of.
I looks like you have the appropriate valves and drains you need to power purge using the fill valve.I think I would do some more research and find a good heating contractor. This should be an easy one to fix.
Albert Einstein0 -
purging
Is power purging something I can do on my own? Is there instructions around on how to do so? Thanks0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
