parallel transformer question
gerry gill
Member Posts: 3,082
in Gas Heating
Hi Timmie- thanks for the book shipment. I'm reading your hydronic controls book (i bought them for my apprentice and found myself reading them instead) and have a question about paralleling transformers. I want to make sure i have this right. You have a very good description of HOW to do this but i want to make sure i have it right in my head as to Why i may want to do this.
Am i correct that for example, a no heat call at midnight, and its a blown 75 va transformer on a weil mclain LGB, am i correct that i could take two 40 va transformers and wire them in parallel if i didn't have the 75 va on the truck?
Also am i correct that it is desirable to have twice the va rating as is required?
Thats what i was getting out of reading your manuals anyways, and i hadn't heard that before so i wanted to clarify.
Thanks again for making those manuals available for purchase for those of us who cant make the trip to your school.
gwgillplumbingandheating.com
what
What book??? Where its avaiable??? Thanks0 -
These books
Timmie has some really outstanding manuals written in plain english for us public school types..i would never have figured out the electric brain boxes with out his automatic ignition manual. Attached is his book order form.
Manuals
Timmies books are the best, i have about 10 of them and I am looking forward to picking up his updated manual on multizone relay panels0 -
Thanks Gerry
Am i correct that for example, a no heat call at midnight, and its a blown 75 va transformer on a weil mclain LGB, am i correct that i could take two 40 va transformers and wire them in parallel if i didn't have the 75 va on the truck? THAT IS CORRECT, WHEN WIRING IN PARALLEL THE VOLTAGE REMAINS CONSTANT AT 24 VOLTS BUT YOU INCREASE THE WATTAGE (VA) SO TWO 40 VA TRANSFORMERS WOULD GIVE YOU 80 VA.
Also am i correct that it is desirable to have twice the va rating as is required? NOT NECESSARILY IT IS JUST THAT BIGGER IS ALWAYS BETTER. HERE IS HOW IT WORKS, FIND OUT THE AMPERAGE DRAW OF THE DEVICE YOU ARE GOING TO POWER ...SAY A GAS VALVE WHICH DRAWS .4 AMPS YOU MULTIPLY .4 TIMES 24 VOLTS THAT GIVES YOU 9.6 VA SO A 10 VA TRANSFORMER WOULD WORK. NO HARM HOWEVER IF WHAT IS ON THE EQUIPMENT IS A 20 VA.0 -
MikeyB I am still working
on the multi-zone panels book. The more I dig into this particular subject the more that gets added. I am actually thinking of making them a part of my Hydronics Manual that is #5 in the catalog. What it would become is as follows:
Basic Hydronic Controls Volume I (this would be my existing manual with a name change)
Hydronic Controls Volume II (older multi-zone panels)
Advanced Hydronic Controls Volume III ( the new stuff)
I will keep you posted, it is just that I get so busy with day and night classes I do not have time to sit down and work on these manuals. So much to do so little time.0 -
Thanks Timmie
that clears it all up!gwgillplumbingandheating.com
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
