Heat a Remote Camp
zvalve
Member Posts: 83
Any thoughts on how to heat a remote uninsulated cabin, not on the grid, during the months of May to November. It is on Martha's Vineyard and even during July and August it can get incredibly damp and foggy so a good source of heat like a wood stove, which I had been using but more about that later, was a welcome respite from the damp and with the door open it never got too hot. The insurance company nixed the use of a wood stove unless the chimney was moved to the center of the structure. I know, move the chimney and the stove but it would cut down dramatically on living space.
What type of fuel
What would you like to use for fuel?..I assume it would have to be wood, coal, oil, or LP gas.0 -
Heat a Remote Camp
Wood, propane or passive solar0 -
Propane
Would a small propane stove make sense?
It would take no electrical power.
Albert Einstein0 -
Heat a Remote Camp
I have a Little Buddy heater but is there anything better or more sustainable. I suppose I could use an old stove as an outdoor boiler and rig up a thermosiphoning system with a small tank in the cabin which is above some fined
radiant pipes which eventually return cooler water to the stove but that seems too complicated.0 -
Willliams Furnace
http://www.e-wfc.com/pdf/L1457_High-Efficiency%20Direct-Vent.pdf
this would be a simple way that is quite and requires no electricity.
The issue with solar is when the demand is the highest output is usually nill.
My house has passive solar with thermal storage which complements the radiant floor hydronic system.0 -
Williams Furnace
Thanks for the reply. It looks good. I suppose I was trying to get something for nothing with the original post but also naively thought there might be something out there that was overlooked.0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
