Humming coming from inside boiler
tombstone
tombstone Member Posts: 30
Good Morning!
I am hearing a faint humming coming from inside my boiler and am trying to troubleshoot it. This is what I've discovered thus far.
1) If I turn power off to the boiler the humming stops.
2) If I turn the thermostat off but keep the power on the humming continues.
This very well may be a normal condition, but I had the boiler enclosed on three sides and may not have heard it before. I tore down one of the walls to access some piping before I fired it up.
I'm not overly intimately familiar with everything concerning this boiler and am looking for things I should check.
Thanks in advance for any and all help.
  • Ironman
    Ironman Member Posts: 7,855
    Transformer
    It's probably the normal 60 cycle hum that comes from the control transformer. Does it stop when you turn off the circuit breaker or service switch?
    Bob Boan
  • tombstone
    It does stop with no power ...
    Yes. If I turn off power the humming stops. It doesn't if I just turn down the thermostat so it's not calling heat.
  • Slimpickins
    Slimpickins Member Posts: 359
    Need to know
    Is it humming any particular song? If it starts whistling the theme song to the Andy Griffith show you have a problem. Seriously, like Ironman said its probably a transformer.
  • tombstone
    edited October 2013
    lol ...
    If that was the case it'd be a youtube sensation ...
    It looks like my boiler has an internal AC to DC conversion circuit.
    Thanks!
