Humming coming from inside boiler
tombstone
Good Morning!
I am hearing a faint humming coming from inside my boiler and am trying to troubleshoot it. This is what I've discovered thus far.
1) If I turn power off to the boiler the humming stops.
2) If I turn the thermostat off but keep the power on the humming continues.
This very well may be a normal condition, but I had the boiler enclosed on three sides and may not have heard it before. I tore down one of the walls to access some piping before I fired it up.
I'm not overly intimately familiar with everything concerning this boiler and am looking for things I should check.
Thanks in advance for any and all help.
Transformer
It's probably the normal 60 cycle hum that comes from the control transformer. Does it stop when you turn off the circuit breaker or service switch?Bob Boan
It does stop with no power ...
Yes. If I turn off power the humming stops. It doesn't if I just turn down the thermostat so it's not calling heat.0 -
Need to know
Is it humming any particular song? If it starts whistling the theme song to the Andy Griffith show you have a problem. Seriously, like Ironman said its probably a transformer.0 -
lol ...
If that was the case it'd be a youtube sensation ...
It looks like my boiler has an internal AC to DC conversion circuit.
Thanks!0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
