Whats the differance
hairball
hairball Member Posts: 19
Is a a BTU the same as a BTUH?
  • Ironman
    Ironman Member Posts: 7,942
    BTU....BTUh
    BTU= British Thermal Unit: the amount of heat required to raise the temp of one pound of water one degree.
    BTUh= BTU per hour. It puts a time frame on the measurement. One hour is the standard and is normally assumed unless stated otherwise.
    Bob Boan
