Whats the differance
hairball
Member Posts: 19
Is a a BTU the same as a BTUH?
BTU....BTUh
BTU= British Thermal Unit: the amount of heat required to raise the temp of one pound of water one degree.
BTUh= BTU per hour. It puts a time frame on the measurement. One hour is the standard and is normally assumed unless stated otherwise.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
